After you find out that those weren't the problem, try this......
Pull the radio and FI fuses, close all doors, turn off all accessories, etc. Remove the NEG battery cable and let it lay loose. Place a multimeter, set on amps, and connect between the still connected POS terminal, and the LOOSE CLAMP, NOT battery post, but the loose CLAMP, and read the current load.
Do not read current (AMPS) from pos to neg on the battery terminals with your run-o-the-mill meter. It will immediately fry.
You still may get up to 0.5 amp load, but anything higher than that, (With ALL accessory loads removed as described) means you have a short somewhere. Give the meter a break to cool ( only read load for 10 secs at a time every few mins) and then start the real fun.
Get a buddy to make things quicker. Start pulling fuses and CB's one at a time, watching for the meter to fall to zero. When it does, that's the curcuit that's causing the drain, and the one you should focus your attention to. It may feed the iggy, the radio, the int. lights, or a dozen other curcuits, but at least you'll have narrowed it way down. If all the fuses and CB's are pulled, and the drain remains, then it's on a curcuit directly to the battery and bypassing the fuse panel. Added any relays, lately?
Sounds fun, huh?
