Reject. Looks like autocorrect got you. Wear your damn seat belt.
Straight bodies are for car shows. Enjoy that lumpy Pig! Looks like a fun place to start and enjoy.This is my 4th pig and second 74. She's all original - F155 and 4 speed. No immediate plans other than to just drive her as is and, maybe, try and fix the dent in the driver's side fender and door. She's on her way to TN from Albuquerque with a few extra parts. Looking forward to seeing her tomorrow, I believe.
‘74 w/ a 4-spd might have the transition gear in the t-case.This is my 4th pig and second 74. She's all original - F155 and 4 speed. No immediate plans other than to just drive her as is and, maybe, try and fix the dent in the driver's side fender and door. She's on her way to TN from Albuquerque with a few extra parts. Looking forward to seeing her tomorrow, I believe.
As I recall, and I've done it twice, the transition case is special as it is allows you to put the gears from a 3-speed case into it. The crawl ratio jumps a massive 4% or 6% or something like that. There used to be a write-up in the tech links but I can't find it anymore.‘74 w/ a 4-spd might have the transition gear in the t-case.
I don’t remember the exact ratio, but it is a deeper Lo range.
We're about 600 VIN apart...Sorry, Thomas, it’s been raining so much here, I have it at the in-laws in their shop. It’s a Dec ‘74 build.
According to the interwebs:
Not yet. The tires on those wheels hardly have any wear on them, but the date code is mid 2008. Still might go ahead and put them on because I’ll be in the midst of short trips just to get it sorted for quite a while I expect.
Usually, one could safely assume that, but not in 1974. It was a transition year and the big change was scheduled for 1/1/'75 so they built the '74s right up to the last minute. I had to go 'round and 'round with the smog nazis about this once...So I assume your frame is a 1975 model?
Where are you measuring the vacuum from? Usually we use a port on the intake manifold. 12" Hg is low for manifold vacuum at idle. 20" is good.The vacuum for the crankcase at idle was -12 in Hg, which seems a little on the high end.
That may not be the best place to get an accurate vacuum reading. But it might be, I don't know. I use one of the threaded ports right on the manifold.I connected the gauge to big vacuum port on the spacer between the carb and intake.
