73fj45 lights
south australia
i have rerplaced lights with crystal ones then few day later i lost low beam high beam works,so i replaced indicater/combination switch and headlight switch and still no low beam does anyone have a wiring diagram also i checked fuses on fusebox and checked the square box thing on engine bay looks ok
You getting power out of the low beam contact on the back of the switch?
re lights
i just went to auto elec and replaced the light relay in engine bay seems like no power to low beams at light plugs there is power to switch on dash how do i resolve this easily lol just an update connected power from park lights on to lowbeam on headlight and they worked how can i fix it easily as need the car for work
You might have a broken wire between the low/high beam switch on the steering column and the lights. Unless it's been modded the 40/45/47 series directly switches the 12 volts, not through a headlight relay. Friend had the same problem as you and it turned out that the soldered connection on the high/low beam switch came off, resoldered it and it's good.
re lights
thanks heaps herb had a look at colum and noticed wire had come out of plug quick push and lights on if only new that b4 replacing everything lol least shell go for anoth 30 years regards shane:clap::cheers:
