63 front axle
Status
Not open for further replies.
New here looking to convert my 63 chevy 2wd to 4wd. Was wondering what axle came stock in the 63 4x4? Also what axle I could use as a front axle with out changing the rear axle.
just make sure they have the same gear ratio, stock is a closed knuckle Dana 44, you may also need different u jionts of a differen't flange for the pinion, I threw in some pic's of a guy that used a blazer frame to convert, he had to cut down the bed a few inches to make it work, if I did it over this is how I would go. You should know that the stock truck has a lot of lift out of the box, they are spring over and have blocks in the back like 6 inches, you would likly have to ditch the ibeams and find a doner 4x4 frame and move it over..
Status
