60 SERIES REAR QUARTER MOLLE PANELS - 3 MOUNTING OPTIONS FOR INTERIOR AND EXTERIOR
N Cascades DsnWrx
Supporting Vendor
Winthrop, Washington
Website
www.northcascadesdesignworks.com
I've just ordered the parts to build up this new product that I've been testing for a few months now. I will have the suction cup mounting solution available first and have the next revision of prototypes for the other mounting solutions arriving soon and once those are proven, I will drop those as well. If you are interested, visit my website and you can sign up to be notified when they come in stock. No purchase necessary at this time.
The new North Cascades Designworks 60 Series Landcruiser Rear Quarter MOLLE Panel is a great solution for getting quick access gear in a position that is easily accessible and off the floor of your hatch so you have room for larger equipment, slide-outs, bags, coolers, etc. Mount MOLLE pocket bags, recovery gear, water container, First-Aid kit, fire extinguisher, holster, flashlight, or whatever you can dream of needing handy.
You can purchase the panel alone or pick one of our 3 mounting options. Mounting options include: a suction cup mounting solution for no drill, interior mounting; a hard mount option that requires drilling and/or installing rivet-nuts; or an exterior gutter mount option that pairs with our roof rack and has more capacity for heavier items like fuel cells, water containers, or propane tanks. Up to 4 Rear Quarter MOLLE Panels can be mounted on one vehicle with our combination of mounting options!
Features Include:
  • 0.125” thick marine grade aluminum and satin black powder coated for a durable finish
  • MOLLE pattern matches military standard packs and accessories for easy assembly
  • 3X Daisy Pattern holes for mounts and hardware to attach your bolt on accessories or accessories that come with their own mounts
  • Mount location for Baja Designs Dome Light for more interior lighting, biased near the rear of the vehicle for easy reach
  • Easy drill aluminum if you want to customize mounting solutions as needed
  • Choose from 3 Mounting Options (Specify When Ordering):
    • 4X - 4.5” Suction Cups - These high end, camera grade suction cups have a high capacity rating and can be recharged by pumping the button located on their body. Total panel capacity is 25 lbs. and it is recommended for interior use. This is a no-drill option for those wanting to add mounting space to their classic while keeping the vehicle as stock as possible. Includes black oxide stainless hardware for mounting the suction cups to the panel. (These suction cups have many uses and are available separately on our website)
    • Hard Mount Brackets - Our Hard Mount Brackets increase the total panel capacity to 35 lbs. and is also for interior use. This mounting method is more permanent and requires drilling. Includes black oxide stainless hardware for mounting the brackets to the panel. It is recommended to install 1/4” threaded Rivet-Nuts into the desired locations (Not Included).
    • Exterior Gutter Mount - The exterior Gutter Mount option comes in a LHD Driver’s Side and a LHD Passenger’s Side configuration (Order opposite sides for RHD vehicles). Exterior mounting makes room for mounting fuel cells, propane tanks, and other accessories you may want easy access to on the exterior of the vehicle. Comes with the exterior mounting brackets and 2 suction cups that secure the bottom edge of the panel. Includes black oxide stainless hardware for mounting the suction cups to the panel. Pairs well with our roof rack.
PHOTOS ARE THE FIRST PROTOTYPE, THE ACTUAL PRODUCT WILL BE SLIGHTLY DIFFERENT AND WILL LOOK LIKE THE CAD RENDERINGS.
Find this product on our website at this address:
Rear Quarter Molle Panel - North Cascades Designworks
I will have the Suction Cup Mount option available soon and am getting the next revision of prototypes for the mounting solution that I just need to verify before ordering production quantities for those. Prices are preliminary but should be very close to retail. I'm ordering small quantities until I can get some traction on these items.
I got the prototype gutter mounts for the rear quarter window panels yesterday. They fit well and I will place my order for production units soon. They are posted on the website and you can be put on the list with no commitment to buy. They mount via the gutter so you do not need the roof rack to mount them! Compatible with the North Cascades Designworks roof rack, may fit with others but will depend on where the clamps are located on those racks. Will need to specify driver's or passenger's side when ordering. I HAVE ONE OF EACH AVAILABLE NOW NORTH CASCADES DESIGNWORKS, LLC - https://www.northcascadesdesignworks.com/
The interior suction cup option is AVAILABLE NOW as well. I've got the interior rigid prototype mounts in hand and just need to verify them before ordering production units. These require drilling and installing Rivet Nuts but have a higher capacity than the suction cup option (35 bs. vs. 25 lbs.). The suction cup option is a no drill option that keeps your classic in stock condition. They are high quality suction cups with a pump mechanism that allows you to easily recharge them.
rearquartergutter-jpg.3668414
OCTOBER SALE - 20% OFF FOR ALL IH8MUD MEMBERS, FREE SHIPPING ON AVAILABLE INVENTORY. USE CODE "CLOSEOUT20" AT CHECKOUT. OFFER GOOD THROUGH OCTOBER 31. www.northcascadesdesignworks.com
How does this attach to the truck?
Im tempted. Real tempted.
Not even driven mine is two years (though that's changing VERY soon), but I dig this idea
Dang! I don't know how I missed this @HMP . So there are 3 mounting options:
See link to the website for more details and feel free to contact me also!
Cheers,
Doug
Great work Doug, thanks for bringing these to market. I'll place my order once I get my drawers installed and asses the space.
Cheers, James
