Wanted to have a switch for my carb fan, so I can switch it on when I think things are too hot, not when Mr. T thinks.
Here's the relay, I accidentally got the wrong one; make sure you get normally open for this application.
This is the hot wire to the lighted toggle switch.
Ground wire from switch to factory ground on fan.
Hot wires to relay from battery.
Hot wire to fan from relay.
Purdy lighted switch where the hand throttle would mount, didn't feel like digging to get the wires to the hole over to the left where the mysterious red light normally is, but will move when I get the hand throttle.
Not the greatest place to route the wire, but didn't feel like tearing into the wire loom. This wire will be replaced with a 10g or bigger and be run around the firewall in the next few days.
Notched this rubber plug for the switch and stereo amp wires to pass through.
I think it works well.
Two channel amp for now, wired up to front doop speakers, fade adjusted on head-unit for more power to rear speakers. This combination works OK, and eleminated distortion which is why I wired it in. will be replaced by a 4-channel, and this one will be relocated and will be powering two Kicker L7 12" Subs.
Another little contraption I made up. I had several leaks in the line running to my rear sprayer, so I unplugged it at the union right in the DS floorboard (the cause of my "liquid" that resulted in me tearing out half my carpte), snipped the very end off a pen, and put it in the end of the hose. Nice little stream for those pesky pedestrians.
And another reason to be careful taking apart your dash. Even in 90* heat this happened.
