4WD poping out
David*BJ70
Looking forward to reach the end of the world
Montréal, Canada
OK, I finally know what was my problem.... for the one how already read the other thread.
I removed my rear drive shaft to know where was my 4WD problem. First I was thinking about the hubs, then my birfields, ...
Finally, I find my 4WD poping out when I engage it on the 4H (and 4L) (wtihout the rear divre shaft). I moved the arm and feel it grinding on the gear. Some time it work, then poping and after it realy hard to engage.
I'm afraid I have to rebuilt my T-Case ?
Ajustment ?
Just a new gear ?
And what kind Cruiser T-Case can fit in my ? I have 1983 BJ60.
FJ/BJ40 - 42 ?
FJ62 ?
Thank for your advice.
idea???
I have to ask if you have checked your motor mounts? I had something very similar & found it by the mount finally giving away while wheeling. Stand to the side & have someone torque the motor looking for it to arch up when under the load.
-maybe not a transfer case yet???
You may also want to the spring ball bearing thing that helps to hold the shifter in place. On the passanger side (LHD) there is a bolt that houses a spring and ball bearing. Take that out, don't loose the ball bearing, and stretch the spring out a little, then replace. May not be your problem but one the skid plate is removed it's only a 10 minuted job. You can also try adjusting the linkage on the shifter.
