For Sale 4.56 third members , 8 hp and 2 x 9.5” 2 with lockers
joekatana
GOLD Star
Texas
ALL THIRD MEMBERS ARE SOLD
cleaning up the shop a bit and getting rid of some parts I probably won’t need anymore.
I have a set of 4.56 gears that I was running in my black HZJ73, front is a 8” High Pinion with a lock rite locker in it and the rear is a 9.5 with oem limited slip locker.
8HP with lock rite 350$
9.5 's are SOLD
9.5 with limited slip 250$
I have a 9.5” open with 4.56 gears also that came out of a BJ73, oem toyota gears and can be used in front axles or full floating rear axles.
9.5 open 150$
View attachment 1643651 View attachment 1643652 View attachment 1643653 View attachment 1643654
I'm guessing these aren't forward compatible with my 80 series with factory lockers. But if they are, I'll take them.
You can bolt these in your 80 if you want to take out the elockers or swap over the gears if that is what you are after ?
Not familiar with the smaller 8" HP do they not require a longer splined inner axle for the E-locker like the 9 1/2" rear?
Only elocked or cable locked ones need the long splines shafts, this one has a lock right in it so regular splined shafts will do.
My mistake, reading too many locker threads. Your are right any after market locker would be a direst bolt in.
If you have a extra 4:56 I'll take them 9.5" & the front 4:56 if you have the set I'll take them shipped to 07604
