37s on a 2nd Gen.... Rear wheel tub hacks??
Everett WA
I'm curious if anyone out there has managed to stuff 37s into their 2nd gen Sequoia yet... I've seen a few online, so I know it is possible, but I am curious if one has to do more than the usual body mount chop and pinch weld stuff up front? anything to hack up in the rear??
Any information will be greatly appreciated
Thanks
Here’s a writeup on a Tundra with great specifics on the wheel well chop and Coastal makes a plate to weld on with max cut clearance. No outer fender trimming is required, all body mount and pinch seam. The article notes the Goldilocks zone for wheel offset as +15 to +25 and that it is critical for both front and rear to avoid any sheet metal trimming. I suspect the rear on the Sequoia is less sensitive due to limited suspension travel from the independent rear vs. solid axle on the Tundra.
This is all good unless you want to do 40’s.
