(EDIT: write up starts at post #13.)
Hi everyone,
I am planning to adjust the valve clearances for the first time on my 2H.
I've done it once before on another car, and from that I learned two things:
-Don't run the engine with the valve cover off. (oil squirting everywhere)
-Engine sure cools off quickly. I had to restart the engine twice to get it back to operating temp during the adjustment.
I've got a couple of questions about it:
1. I need a 46mm socket for the crankshaft nut? (according to FSM)
2. Is that easy to get to, should I access the nut from above or below?
3. How much effort will/should it take to rotate the 2H?
4. It's an auto, so leave it in 'P' I take it?
5. Most important question for me: adjust at operating temp, but can I do all 12 valves before it cools off? Should I restart the engine every 4 valves or so? Or so long as it is not cold? (I plan to do it after a 40km trip into town, and at 30+ celcius)
6. And finally, what is 'a very slight drag'? Enough to bend the feeler gauge as you push it in, or just enough to not be completely loose?
In addition I'll make sure I have all tools at the ready, including the correct feeler gauges
(I=0.20mm, E=0.36mm) to speed things up.
If you have any other tips, let me know.
Thanks,
Vince
Hi everyone,
Thanks,
Vince
