Previously posted the "symptoms" of my recent cruiser rebuild -- problems with idling after warm up. (here's the link the the previous posts https://forum.ih8mud.com/index.php?board=1;action=display;threadid=15306).
Anyway, seems I might have chased down the problem --the dreaded manifold leak. A "cold" manifold seems to be sealed up 'tight' but once the engine gets to full operating temp the intake must warp enough to leak-- I sprayed starting fluid around the intake and no increase in RPMs except for one area around #1 and #2 cylinders-- definite and immediate response. Yeah, I have retorqued the bolts a few times to no effect. Is this a typical scenario of the intake leak occuring after the engine heats up?
So I guess my options are: 1) to take the thing off and have it 'trued-up' a the local machine shop or 2) give the 'two-gaskets' approach advocated by many on this board a try. From what I've read posted here - having the intake/exhaust machined is not a sure fix -- many folks say they still had to use two gaskets to get a good seal. If using two gaskets do you use some hi-temp 'copper' gasket sealer in between gaskets and on the block/intake sides as well?
What's the advice folks? I would prefer to do this only once...
Thanks for the help!
Tom
Tom
