Wanted 2F Carb Auxiliary Accel Pump Spring
Somerset KY
Needing an auxiliary accelerator pump SPRING for a 2f Aisin carb. Carb date is 11/74' For some reason the PO removed the diaphragm, spring, and soldered the vacuum port up. I rebuilt the carb and used a new diaphragm, just missing the spring.
Thank You!
please post photos and a a parts diagram when u can...........
The tapered coil spring int the #7 sub assembly, AAP, Auxiliary Accelerator Pump.
Pretty sure that's a Federal '75 carb.
I'm not sure, but I think I read a post where people have used a wheel Cylinder Spring as a substitute... I can't find the post at the moment.
If I knew the length, diameter, and k value I could order one from mcmaster carr. Hopefully someone has an old carb laying around and or they can measure one for me.
