I believe I have found the glow plug power cable which runs back to a relay up on the front of the left side guard. The relay has two small coil wires which have been cut off. Question is what colour wires should run to the coil on the relay and what should connect to the other pole on the relay?
I have 2 conduits left over, I’m guessing they are for glow plug wiring, one leg has a large diameter cable which is white with little black dots and two smaller wires, one white with a black stripe and brown dots and the other wire is black with a red line and silver dots. The second conduit has the other end of the large diameter white cable with small black dots and 2 small wires, one is black with blue line and brown dots and the other is grey with brown dots. Any idea where these go? Is it possible the 80 should have a glow resistor fitted in he inlet manifold? The 105 series didn’t have this.
I also have a two terminals with no home, one terminal has 4 wires and the other has a single wire. Could this have been for the glow resistor?
Any help would be appreciated. I’m confused as to if this is a fixed delay glow system with only a single relay or the other system which runs two relays. Where would the second relay be fitted?
I can power 12v direct to the glow plugs and it starts and runs fine.
