1hdft sumps (1 Viewer)
aus
This is doing my head in to no end.
I’m looking for a sump that is compatible. With oil sensor.
I currently have a 3 step on there with oil sensor. Which is from factory. I’m doing another build and would like the same sump.
I believe the 1hdt is the same (some do and don’t have the low oil).
But then I’ve seen people using the 1hz with a single step(12101-17100)And that seems to work?
I don’t believe the 100 series 3 step works as it hits the diff.
What are my options?
I think this is the one 12101-17071. I need but they’re all $900~ aus
I would expect a 105 series 1hz sump would work, but not 100% certain.
They have an oil level sensor, and chassis and front diff are essentially the same as 80series. There's minor differences in the chassis, but the major things are the sand such as engine position, suspension, front diff housing etc
1hz and 1hd-fte share the same block and crank cradle etc, so sump should be a straight bolt in swap
Edit, I see the part number you listed is for a 105 series 1hz
