Hello!
I've recently bought a 2000 HDJ100, A/T. It has the 1HD-FTE engine, and it seems to knock a little bit - I can hear it at idle, one knock every rotation.
It seems to be comming from the bell housing area of the engine, although I went through it with a stetoscope and couldn't pin-point it. One thing for sure, if I probe the injector lines, I can hear the 1/rotation knock on those.
I've listened to all possible youtube videos, and can almost hear the same knock in all of them, so I assume it's somewhat normal?
Anyway, here it is. More audible near the end of the video.
Also when sitting at traffic lights the whole vehicle shakes a little (like 1 cm left to right) also about the frequency of 1 / rotation - it's like being on a boat. Not sure if it is related to the knock or something else. The rear mounts are brand new (under the transfer case), but I don't know how the front mounts are.
It's a bit overfilled with oil (2-3 mm's above Full - not sure if there is a leaking spill injector seal yet), so it might be the crank splashing into the oil causing the rocking motion?
