I will say though that I did a "test" pull using a fish scale on the knuckle and while it required about 9 ft-lbs. of force, which was within spec, there were some parts of the rotation that seemed a bit stuck for lack a better term.
Also, the shims on the top did NOT equal the shims on the bottom, which per the FSM seems to be ok as the top shims are used for a different alignment than the bottom shims. Am I interpreting this correctly ? Since I do not have access to the $300-400 tool I am simply going to reuse the shims in the exact same position as when I removed them.
the top isn't necessarily different from the bottom, it depends on the individual axle and knuckle combo. the important thing is that you add/subtract an equal amount (not equal number of shims, but = thickness) from top to bottom. This is to keep the knuckle centered on the axle. If it gets off center your drive axle will wear an oval into your oil seal and spindle bushing. A well manufactured bearing will likely not require a change to the shims, but don't count on it. I used national (best aftermarket afaik) and had to subtract shims.
