When I first started this thread I had broken down the passenger side front axle down to the spindle and stopped because of questions and time constraints. Due to spending time de-rusting and painting the parts I have taken off, weather and my job I haven't progressed from there. I greased the spindle and machine parts so that I could take my time doing this (cleaning them off when it comes time) by leaving certain things exposed until I could come back to them.
I put the bare wheel hub (sans bearings and races) through 24-hour hydrolysis, baked it against any hydrogen embrittlement and cleaned it with POR-15 metal prep. Unfortunately the Rust-oleum high heat primer and paint that I have to finish it off only work at temps of 50 degrees and above. I am working in an open air carport and I don't want to get fumes in the house so it looks like I'll have to wait to finish the painting.
Also, I have found Autozone part number AC3210 -Autocraft Universal Tie Rod Pulling tool to be an exact replica of the OTC tool for much less. Any comments if there is any reason I can't use the Autocraft vs. OTC ?
Here are some pics:
1) Where I started from when I started the thread = where I am now (I do these things slowly for the first time - the other side should go much faster).
2) "Before" what of wheel hub prior to electrolysis:
3) "Before" shot of sacrificial anodes prior to electrolysis; I cleaned up the rotor from the wheel hub and a cheap sheet of plain steel to sacrifice for the cleaning of the wheel hub:
4) Here is the "after" of the wheel hub and sacrificial anodes post-hydrolysis. I would go on to bake the wheel hub for a couple hours @ 350 degrees Farenheit to prevent hydrogen embrittlement.
5) Here is the wheel hub after converting and coating new surface rust with POR-15 metal prep. I have to wait for the weather to warm up a bit to finish with high-heat primer and paint.
