Build 1979 FJ40 Old School Overhaul
Cut floor boards up some more...
Ok, Im not bitching........ well I don't want to be perceived as bitching. :flipoff2:
BUT DAMN!!!! This has been a serious pain!! I got almost 20 hrs in the passenger side floor board and rocker. :censor::censor::censor:
All I have gotten done that counts is welding in the floor, I dont even have the rocker on yet. That will be for tomorrow.:eek:
Looking at the floor pan after it is welded doesn't do justice to the amount of work that went into making it fit properly.
1. Trimmed to fit.. in multiple pieces.
2. Cut in 3 pieces so the ribs would line up.
3. Refit 3 peices, tack weld, pull out and weld up all cuts.
4. Reinstall check fit.
5. Then Cut the 4 piece to tie in the back.
6. Fit, trim, fit, trim, fit, trim, fit, trim, fit trim.
7. Tack weld 4th piece, pull out and weld up.
8. Put back in check fit. check, check.
9. Weld her up..
10. Ohh, I left out all the grinding!!!!!:flipoff2::flipoff2::flipoff2:
Here are some pics.....
Not only had to cut it in 4 pieces for proper fitment.
Notice I also sliced the ribs to make them the proper elevation. So I could hammer them into adjustment.
Alot of work right here.... to get it to yield to fit properly.
Amazing, Doug! Do you think it would've been better to just cut out the entire pan and weld it in instead of trying to line the ribs up?
@adistler1 .... Yeah, it all seems a judgement call.
Figure out how to mark you panel to cut out......Cut it all out..... drill out all spot welds at seams.... repair rusty you are going to weld to......get it all to fit back.......+/- 4 linear feet of welding....
Probably just one day! Instead of 20 hr :banana::banana::banana: job.
You're making me want to do a 3 week pharmaceutical research study to just afford to buy a whole new tub!
If you need me, I'll be perusing www.testwiththebest.com instead up picking up welding supplies.
Good call on welding it back together before installing it. I should have done that. Also nice job with the elevation, mine are not quite flat.
Welded floor pan together... drilled all spot weld holes and drilled the three big drain holes. Just like factory:hillbilly:
I also learned something after almost being done. I drilled 1/4 in holes for my spot welds which is a lot smaller than what I was doing...
That helped with my rosette welds.
