pplkook said:Backspacing WILL NOT help clearing the caliper. The angle of the cone stays constant regardless of the backspacing, and the reason why you are hitting the caliper is due to this angle.
Break out the grinder and grind away, only way to get it wor work. I have tried and tried to find steel wheels that "will work" on my 62, and I must have some goofy over built aftermarket calipers, because the only fix I could find was grinding...
-Jack
