2014-18 GM 1500 Bilstein Shock Options + Forum Discount
Use code GMTRUCKS for forum discount
Bilstein B6 4600 shock absorbers are designed as a direct fit upgrade to OE shock absorbers on stock height light trucks and SUV’s. These shock absorbers feature a monotube design which provides consistent fade free performance. B6 4600 shock absorbers utilize a unique, velocity sensitive, digressive piston which reacts to changing road conditions. All B6 4600 shock absorbers are tuned for each specific application to ensure optimal performance is achieved. B6 4600 shock absorbers offer a significant improvement in ride quality, handling, and comfort.
Bilstein 4600 Front Shock - 24-238281
Bilstein 4600 Rear Shock - 24-238298
Bilstein B8 5100 (Ride Height Adjustable) shock absorbers are designed for trucks and SUVs with a front OE coilover style suspension. Rear 5100s are extended length for use with block kits, add-a-leafs or shackles. In front the multiple snap-ring grooves in the body allow for different spring seat positions, providing 0-1.85 inches of front lift with OE springs (depending on cab size). The monotube shock absorbers feature a 46mm digressive piston a with self-adjusting deflective disc valve setting. Bilstein B8 5100 (Ride Height Adjustable) shock absorbers provide increased wheel travel and improved handling. Utilizing a B8 5100 (Ride Height Adjustable) shock absorber is the easiest way to level out your vehicle.
Bilstein 5100 Front Shock - 24-238304
Bilstein 5100 Rear Shock 0-1" - 33-238319
Bilstein 5100 Rear Shock 3-4" - 24-186636
Bilstein 5100 Rear Shock 5-7" - 33-187228
Bilstein B8 5160 remote reservoir shock absorbers are designed as a direct fit solution for lifted trucks and SUV’s. The remote reservoir will offer increased cooling capacity and wheel travel to optimize overall performance compared to a traditional shock absorber. These shock absorbers feature a monotube design for consistent fade free performance and utilize velocity sensitive digressive valve settings which are tuned for each specific application. Each shock absorber is fitted with a unique 360 degree swivel banjo hose fitting, providing a clean, low profile installation. B8 5160 remote reservoir shock absorbers will increase overall durability of your vehicle allowing you to conquer the harshest of off-road environments.
Bilstein 5160 Rear 0-2" - 25-242515
Bilstein 5160 Rear 1-3" - 25-187601
Bilstein 5160 Rear 3-5" - 25-197761
Bilstein B8 6112 leveling kits are designed to provide more ground clearance, allow for larger tires, and increase wheel travel. Multiple snap-ring grooves in the body allow for different spring seat positions, providing 0-1.85 inches of front lift (depending on cab size). These kits consist of (2) 60mm shock absorbers combined with (2) custom matched cold wound coil springs and (2) billet aluminum spring seats. The large 60mm digressive piston allows for increased damping control for optimal on-road and off-road capabilities. Experience the legendary Bilstein off-road experience with the best direct fit spring and shock kit for your light truck or SUV.
Bilstein 6112 Front Pair - 47-273702
