I’ll order two when they go live again. Was out of town and missed the first round
When’s the next round coming up? Will you be at HIH this year?
They're in stock and for sale now at owlexpedition.com
I will be at 100s and will be giving away a few and should have some to sell.
Pretty slick & great instructions. Easy install. What extinguisher is recommended?
I have 2 of the prototype mounts and they are great. The install/instructions was easy . Removing the "end of rail" plastic covers was annoying. You only need to remove the front seat bolts, and loosen the rear seat bolts enough so the chair can tilt back. I used another screwdriver to simply prop up the seat while I was installing - worked well enough.
On both of my seats, one of the rear seat bolts was significantly tougher to turn and seemed to stop at a certain point - so I stopped trying to remove it after a while (though did use a lot of force before I gave up). I don't know what it was, but it did screw back in just fine.
For extinguishers, I bought a 2.5Lb Halotron Amerex B385TS which is a B/C extinguisher. I have one in my E39 M5 and it was recommended to get a B/C one due to the non-corrosiveness if it ever needs to be used. It cost about $125. The mount only allowed the fitting of 2 holes instead of 4, but I think it's good enough with some lock nuts.
Had this out at HIH9. These are great. No rattles on any of the trails and the H3R extinguishers fit up perfect. Highly recommend.
Just ordered mine. Can't wait to get this installed.
