I was in the process of wiring up a harness for my brand new trailer, when out of no where my right rear turn signal stopped working. I was testing what wires were hot with the blinker on when it appeared to short.
Here's what it's doing:
-It's acting like the bulb is out because the front Right and then indicator on the dash are both blinking fast.
-When I put the hazards on, they all work except the rear right.
-The break/reverse lights work fine.
Again, this started as I was fiddling around with an old, poorly installed trailer harness. So the signals was working fine until this.
Here's what I've done:
I tested the bulb.
I checked thet fuse (even though the other signals still work)
I tested the flasher
I checked the relays
I checked the turn signal/hazard switch
I did everything the Toyota manual says and more, and cant figure this out!
I am leaning towards a broken wire, that is about the only thing that would replicate the symptoms of a burnt bulb...I think. Any suggestions?
I doubt the ground is the problem just because the thing was working fine before and all the other lights but this one still work.
I tested the bulb.
