ok, looks like i need to lose some things as i am loosing my shop space. now, i would rather keep this i cant.
this is what you get. its dusty, its been sitting in the wharehouse for a year.
1971 frame, all axles (i think the brakes were redone),
33" bfg AT tires (4 down to 1/4 tread and 5th 99%)
new white wagon wheels,
new 4.25 turn sag steering box,
new steering cooler,
the V8 is a chevy 289.
new holly 650 carb (way to much carb for it, when i bought it i was told it was a 350 engine)
new billit alu pullys.
its mated up to the stock 3spd trany.
also has (i cant remember his name) front reinforcing plates. so it has the ouside scab plates and inside and top side plates for the front frame. very nice setup.
new powermasters 100amp alt
new high vol oil pump
new water pump
nice custom build rear bumper (takes standard 4" round grommet mount lights
custom front bumper
I am also including the 4link bracket kit from proffit off road. (see pic)
also, the winch is not included.
But i will throw in the stock gas tank (which is in great condition) and the body part that the tank sits in (body was cut up)
$1400 i think its worth it. frame only has surface rust on it.
also, does not come with tital
i can ship, but you have to set it all up. i can help push it on the truck
also if you bring truck, i can help load it, i have forklifts and such here
inclues all this, ececpt for the rod ends and tub adapters
new water pump
custom front bumper
