I put a dual battery system into my HJ60, and have some questions. As a system I used to Mobi-Arc Isolator (http://www.perfectswitch.com/isolator.htm), for the following reasons:
It is built locally
I saw the factory and got a great demonstration of the part
No amperage loss
No heat generation
I need this to power gadgets like fridges and lights, without drining the starting battery.
I put a second stainless battery tray in, and added a deep cycle battery. This connects to the isolator, which connects to the starting battery, which connects to the starter.
The input from the alternator and the fusible link connect to the axiliary side of the isolator.
The aux battery connects to a fuse box inside the cab, which powers outlets in the back of the truck. Like this the starting battery never drains, even if the aux runs completely empty.
Here are my concerns: In my setup, the fusible link connects to the aux battery. So if I drain it completely, things like the starter relay, or the glow circuit would not have power anymore. So even if the starter has a full battery as it's disposal, it would not kick over. This obviously defeats the purpose of the setup.
To solve this, the fusible link should connect to the main battery, but the alternator output should connect to the aux side of the isolator, to be able to charge both batteries.
I don't know how to do that, since the alt first goes into the voltage regulator, and then over 10 other circuits (looks like the in the wiring diagram) to the battery.
Also, in the wiring diagram it looks like there are 3 leads going to the battery, but I have only 2.
couod anyone advise me on how to do this correctly?
thanks
J
here are the pics:
starting battery
aux battery
relocation of washer bottle
It is built locally
No amperage loss
No heat generation
thanks
J
here are the pics:
starting battery
aux battery
