I am Selling my 1988 4Runner to fund my Blown Up 1994 Pick-Up Project. The Truck Has 290,000 Miles on the Odometer "Which Quit Working About 2 Months Ago" I Drive the Truck to Dayton a Couple of Times a Week So I am Guessing the Truck Has about 300,000 Miles on it.
The Frame is OK.
The 1/4 Panels are Toast.
The Doors are OK.
Cut out Rust on Front Fenders. Still Some Rust Left. But, no Rust Holes to Get Cut On.
The 3.0 Runs Very Strong I Don't Know if it Was Ever Replaced? No Oil in Antifreeze or Antifreeze in Oil. It Does Leak oil out of the Front of the Engine. Probably a Front Oil Seal.
The A/C Worked this Summer But, after The Truck Sat in a Creek For a Few Days "This Past Summer" The Compressor has Failed "Sounds Bad So I Just Took off the Belt.
It has OEM Size Tires with About 1/2 Tread Left. OK For Not So Hardcore Trails.
The Windshield Frame is Rusted Out it Leaks when Powerwashed But, Not in Rain. I was Just going to Caulk it.
4wd Works Great I wheel This Truck Weekly at Local Trails.
The Automatic Transmission Shifts Good. But, on Steep Hills if you Come to a Stop and Sit there For a Second the Truck acts Like it is out of Gear Until you get the Revs up and then it acts Like you Have Just dropped the Clutch in a Manual.
Back Window Just Quit Working Last Week and it is a PITA to get BMX Bikes in and out of. I Could not figure out What is Wrong With it?
Exhaust is Good.
Brakes are "Spongy" Might Just need Bled, Might Need a Ton of parts. They Work good Enough For me So I have'nt Investigated Much.
I am Sure I have Missed Lots of Details.
The Truck is Rough, Drives Great and is Priced Accordingly.
Call 614-746-4537 For a Test Drive.
Dax
The Frame is OK.
The Doors are OK.
Exhaust is Good.
Dax
