Parting out 1995 Tacoma
Parting out a 1995 Tacoma (Xtra Cab). It was rolled. Let me know what you need. Color is red with tan interior. Parts are not removed from the vehicle until they're sold. Prices are negotiable between seller and buyer.
T-case crossmember and rubber mount
parking brake handle and forward cable
rear half of parking brake cable and brackets
RH/LH rear spring U-bolts, lower shock mount plates, and rubber bump stops
both front brake calipers with clips and mounting bolts
heater core and box
heater blower motor assy
heater/vent/defroster ducting
driver's sun visor
gas tank lid and hinge
clutch master cylinder
clutch slave cylinder
plastic battery tray and battery hold down bar
Driver seat w/center armrest, seatbelt buckle, and headrest
seatbelt for center section of 60/40 seat
hood latch and release cable
RH/LH hood hinges
RH/LH upper and lower front door hinges
RH/driver door latch mechanism
RH/LH door light switches
chrome exterior left hand door knob/lever and lock
RH/LH door stops
RH/LH plastic door sill covers
RH/LH triangular black door panels that cover the mirror mount bolts
RH/LH plastic kick panels
cabin dome light and lens cover
windshield wiper motor
tubular windshield wiper arm assy
Left and Right hand headlight assemblies
drivers side parking light
front anti-sway bar with end links
complete rear axle, 3.58:1 ratio
tilt steering column with airbag (not deployed)
ignition swich and key
steering wheel
Airbag controller
Complete dash
Driver's rear quarter window
one universal (RH/LH) latch for rear quarter windows
RH/LH weather strips for quarter windows
RH/LH coat hanger clips and screws
weather strip for rear window
RH/LH weather strips for front doors
RH door interior panel with speaker cover
RH/LH door arm rests and screws
RH/LH door speakers and wiring harness
passenger door mirror
Passenger door window and crank assy
driver's door window crank assy (no glass installed)
RH/LH door window trim strips
rear seat cupholder
black trim and screws for floor board access below the rear seat
gas tank and pump/sending unit
gas lines, three of them
RH/LH rear folding seats and backrest
RH/LH rear seat belts
rear seat trim panel with seatbelt buckles
RH/LH rear interior panels
cab rear tailight (above rear window)
Spare tire and steel wheel
two piece front skid plate for differential and engine
black plastic valence below the windshield
brake pedal lever assy
clutch override switch (on dash)
hazard light switch (on radio bezel)
clutch switch/brake light switch (on brake/clutch pedal)
black center hub caps for 87-95 Toyota SR5 alloy wheels
If you e-mail me I can send you digital pics.
Is the rear driveshaft two pieces? If so how much for the second half ( the one with the CV on it).
Mark
Mark,
Yes the rear driveshaft is two pieces. For the rear half (CV to diff input flange) $155. That includes shipping via FedEx ground plus the 3% Paypal fee. If you want the whole thing, from tranny output flange to diff input flange, including the center bearing the price is $258 shipped.
John
Got any pictures of the doors, looking to make some half doors. Shipping to business 17055.
I'll try and post some. If they don't work, send me your e-mail and I send them to you. Driver's door is same as passenger's only damaged at the top. $200 plus FedEx ground shipping to your address.
Do you happen to know what shipping may run, or give me your zip and I will try and figure it out.
My zip is 99518. I don't know what shipping would be off the top of my head. Would have to remove and weigh a door. Sending them down via ship or a freight company (truck) might be cheaper.
do you have a tow hitch by chance to fit on 04 Tacoma?
