Wheel Spacers! All Models, Including New 5x150mm For 98+ Uzj100 Hzj105 & 07+ Tundra
Status
Not open for further replies.
Letsgomoreplaces
Gear & Axle parts for ALL Toyotas new or old...
SILVER Star
Washington
www.letsgomoreplaces.com
WHEEL SPACERS!
6X5.5 (6LUG) LAND CRUISER LX450 FJ40 FJ55 FJ60 FJ62 BJ70 FJ80 FZJ80, 4WD PICKUP, 4RUNNER, TUNDRA (TO 06), TACOMA, SEQUOIA,
1", 1.25", 1.5" THICK $79 pair
2" THICK $99 pair
3" THICK $119 PIER
5x150mm (5LUG) Wheel spacers for 98+ 100 series LANDCRUISER, LX470, 07+ TUNDRA (ALSO OTHER INTL. APP.)
Provides additional clearence for wider tires!
Includes low-profile conical lugnuts to attach spacer to wheel hub.
1.0", 1.25" or 1.5"THICK $175 pair
EMAIL OR CALL FOR CUSTOM APLICATIONS
install
You remove the wheel, bolt on the spacer w/ supplied lugnuts. The spacer has another set of studs in them that your wheel bolts to with your stock lugnuts.
set ordered (1.5"). Thanks for your support! :cheers:
HOLY CRAP THAT WAS FAST!!!!!! I ordered them on the 19th at about 1400, they got here on the 20th at about 1500. Awesome!!!! :cheers:
thanks
Thank you! it helps that your only 1 state away too.
More 5x150mm 100 series wheel spacers are in stock now too.
We are now stocking the 5on150mm spacers in:
1" 1.25" and 1.5" thicknesses $199 pair
are you guys gonna make a 2" thick wheel spacer for the 5x150 pattern in the near future?
spacers
No plans, as that is wider than most want. I do have 1.5" thick IN STOCK
I imagine this has been answered elsewhere, and I figure I know the answer, but..
Does anyone make a space/adapter to go from 5x150mm to 6x5.5in? I'd love to run 6x5.5 on my 100.
Thanks.
well
Well anything can be done. But there are several problems with this. One is they will be super expensive, the other is with different lugs they will need to be 2-piece and will have to be at least 2" wide each. It would be far less money and better just to use different wheels, there's actually quite a few choices since tundra is now 5x150
Thanks.
Carl,
You have anything in a 1/4" 5x150 option??
I am running larger tires on a stock Tundra rim and need just a hair more
aaron
I do not, I do have 1" in stock that is what I've run on mine for years. I also am running tundra rims with snow tires w/ LC rims in summer.
Carl,
aaron
Status
