right front leaf spring
  • Reactions 0
  • Comments 0
transmission leak
transmission leak
  • Reactions 0
  • Comments 1
transmission
transmission
  • Reactions 0
  • Comments 0
U joint
U joint
  • Reactions 0
  • Comments 1
rear shaft
rear shaft
  • Reactions 0
  • Comments 0
rear axle
rear axle
  • Reactions 0
  • Comments 0
exhaust pipe hanger
exhaust pipe hanger
  • Reactions 0
  • Comments 0
hand brake cables
hand brake cables
  • Reactions 0
  • Comments 1
hand brake
hand brake
  • Reactions 0
  • Comments 0
left front stearing connection
  • Reactions 0
  • Comments 0
frame rot right rear only
  • Reactions 0
  • Comments 0
right rear shock
right rear shock
  • Reactions 0
  • Comments 0
radiator left side
radiator left side
  • Reactions 0
  • Comments 1
front U joint
front U joint
  • Reactions 0
  • Comments 0
front leaf springs
front leaf springs
  • Reactions 0
  • Comments 0
fuel tank
fuel tank
  • Reactions 0
  • Comments 0
worn bearing
worn bearing
  • Reactions 0
  • Comments 1
spun bearing front of engine
  • Reactions 0
  • Comments 0
piston bottom view
piston bottom view
  • Reactions 0
  • Comments 0
piston bottom view
piston bottom view
  • Reactions 0
  • Comments 0
oil strainer and pipe
  • Reactions 0
  • Comments 0
oil pickup connection points
  • Reactions 0
  • Comments 0
crankshaft scoring at piston 1
  • Reactions 0
  • Comments 0
front of engine bottom end
  • Reactions 0
  • Comments 1
front crankshaft timing gear
  • Reactions 0
  • Comments 0
connecting rod cap
connecting rod cap
  • Reactions 0
  • Comments 0
connecting rod at rear on engine
  • Reactions 0
  • Comments 0
cam shaft2
cam shaft2
  • Reactions 0
  • Comments 0
cam shaft
cam shaft
  • Reactions 0
  • Comments 0
bottom end view from rear
  • Reactions 0
  • Comments 0
bottom end 5
bottom end 5
  • Reactions 0
  • Comments 0
bottom end
bottom end
  • Reactions 0
  • Comments 0
1st engine service 2
  • Reactions 0
  • Comments 0
albert rodrigues
BJ40 Bottom End Inspection and Repairs
Pictures of 1st bottom end service. General pictures of underside of vehicle
Album information
Album owner
albert rodrigues
Date created
Item count
33
Album privacy
albert rodrigues
Can view media items
Everyone
Can add media items
Album owner only
Share this album
