Solution to the 24volt bulb question!
Ok folks I JUST finished replacing all the burned out internal lighting in my 24V BJ74 with LEDs.
How you ask? Where on earth did I find 24V Wedge , and festoon LEDs?
Well the answer is I didn’t I had been searching high and low for replacement bulbs for the dash lights, heating/AC panel etc… all with VERY little luck. I thought HEY why not go for LEDs, thell last forever and they pull less power, but alas no such thing has been built commercially.
BUT don’t fret I found a solution!!!
Resistors! Now im sure any electronics guy here already figured this one out some time ago, but I recently had the brain flash, tried it out and Presto chango they work like a hot damm,
You will need the following….
(V1-V2)/Current=size of resistor needed
V1 is the system voltage so =24V
V2 is the voltage you want to have so=12V
Current is the current draw from EACH bulb you can figure this out with a multi meter or it may even be published on the website of wherever you buy your bulbs. The site I ended up using has them all published. SUPER BRIGHT LEDS home
From the website I find that mini wedge bulb I ordered to replace the burned out 24 incandescent in the heater/ac panel has a current draw of 12ma =.012A. So the formula should look like this:
(24-12)/.012=1000
So a resistor (or series of resistors) totaling 1000 ohms is what you need to solder/shrink-wrap into the circuit
Anywho just incase someone was looking for an alternative…
EDIT:
Adding Nov 4, 2008
I was starting to run into some troubles over the summer with this installation and found a more reliable method to get the 12V bulbs to work properly....
Go to your local electronics store and buy two types of voltage regulators
a 7812CT, and a 7818CT these things are cheep (less than a buck each where I got them)
you can get data sheets on them here:
L7812CT Datasheet - 500mA positive voltage regulator, 12V from SGS-Thomson Microelectronics
What you want to to is solder the output of the 18CT to the input of the 12CT, and connect both of the grounds to each other+ to a ground on the truck.
Then supply the 18CT input with 24V, and presto you have a regulated 12V off of the output from the 12CT, just be sure your not using standard bulbs because I think this setup is only good for 1 amp, but problem is now solved!!
(24-12)/.012=1000
EDIT:
Adding Nov 4, 2008
