I tested my Charcoal Canister according to the tests in the FSM.
IH8MUD Forum - View Single Post - No power at altitude
It tested bad. My results are:
Per the FSM: Blow into the Tank pipe and air should flow without resistance out the other two.
My test: Blow into Tank pipe and air did NOT flow out of other pipes at all.
Per the FSM: Blow into Purge pipe and air should NOT flow out of other pipes.
My test: Blow into Purge pipe and air did NOT flow out of Tank pipe but did flow freely out of bottom vent line.
I didn't have access to the low pressure air supply specified, but I just blew into the hose as softly as I could, generating what I think would be less than 2.5 psi.
Does this make sense? It would almost be correct if you switched "Purge" and "Tank" in the FSM tests.
I found another low mileage one and asked the same test be performed, and it failed also.
Could there be an error in the FSM regarding this test, or is it just that common for these to fail?
in September and don't want issues as she hates the beast anyway. :whoops:
