Knuckle rebuild video - final video in the series
Hi Guys,
I've made the last hub/knuckle/brake etc rebuild video, go here to check it out:
Toyota Land Cruiser front Knuckle rebuild tutorial - YouTube
And these are some of the other videos in my series:
Video #1 Toyota front knuckle, hub, and brake service overhaul Video #1 Removal.
Toyota front knuckle, hub, and brake service overhaul Video #1 Removal. - YouTube
Video #2 Aisin Manual hub (free wheeling hub) rebuild Toyota Land Cruiser
Aisin Manual hub (free wheeling hub) rebuild Toyota Land Cruiser - YouTube
Video #3Land Cruiser rear brake service, shoes, drum, emergency brake adjustment
Land Cruiser rear brake service, shoes, drum, emergency brake adjustment - YouTube
Video #4 Land Cruiser rear hub/axle service, bearings, axle, seals, gasket etc
Land Cruiser rear hub/axle service, bearings, axle, seals, gasket etc - YouTube
Video #5 Slee Castor Correction Bushing install, Land Cruiser Tutorials.
Slee Castor Correction Bushing install, Land Cruiser Tutorials. - YouTube
Video #6 Land cruiser 1HZ 1HDT 1PZ Valve shim adjustment tutorial
Land cruiser 1HZ 1HDT 1PZ Valve shim adjustment tutorial - YouTube
Video #7 Warn 8274 winch rebuild series #1, disassembly of winch
Warn 8274 winch rebuild series #1, disassembly of winch - YouTube
Video #8 Warn 8274 Rebuild video # 2 Re-assembly of winch
Warn 8274 Rebuild video # 2 Re-assembly of winch - YouTube
These videos are great!! Thank you!!
I've just completed rebuilding my passenger hub/knuckle.
A few quick questions:
1. How tight do you tighten the oil seal on the back of the knuckle (i.e. the one made of felt, rubber, and steel pieces)?
2. I didn't remeasure for the appropriate shims, but just put the original shims back - that's okay right?
3. I don't have a spring tension gauge. How important is it that I measure the preload?? What is the purpose of this??
Thanks in advance!!
Thanks in advance!!
2) If they fit the correct tolerances. If not you need the correct sized shims.
3) Its important in the sense that you bearings will be either be too tight or too loose making them wear quicker than usual.
