I have a Canadian HJ60 (24 volt) that just developed a problem with the heater/defrost fan control. The first two speeds of the fan switch does nothing. The fan operates normal in the third and fourth speed settings though.
I don't think that it could be a problem with the blower motor as it still operates normally in the two high speeds.
Could it be the switch(??) or is there something else that I should be looking at? When I put the fan switch in the off position I can hear a relay click coming from behind the dash behind the area where the dash light dimmer knob is.
The fan switch just stopped working properly a couple of days ago. Seems everything starts breaking down in the cold weather!!!
to your ingenuity! How did you know to use a 1.5ohm resistor? Does the FSM state it?
