I am doing a restoration and would like to clean up my fire wall. I would like to fill in all the holes that are not going to be used. The problem is my FJ is all apart and I have forgotten what some of hole are used for. It would be great if you fellow IH8muders could fill in the blanks below. Pictures are worth a thousand words, to me. Much thank!
I will update as more information comes in.
Check out my restoration below…
https://forum.ih8mud.com/40-55-series-tech/393236-project-landroc-5.html
1) Heater blower box
2) Electrical wire grommet
3) Bracket for supporting the upper tube off of the heater valve
4) Cowl vent drain tube
5) Temp sender wire
6) Throttle cable
7) Master cylinder (brake)
8) Master cylinder (clutch)
9) Mounting nut, not a hole
10) Heater hoses
11) Cowl vent drain tube
12) Heater Warm/Pull cable
13) ?
14) Choke cable
15) Throttle
16) Steering
5) Temp sender wire
6) Throttle cable
10) Heater hoses
13) ?
14) Choke cable
15) Throttle
16) Steering
