- Joined
- Sep 23, 2003
- Threads
- 356
- Messages
- 2,573
I purchased a NOS Aqualu tub about a month back from a guy in NH. It has not been installed on any vehicle. I found a crack in the door sill and am still scratching my head as to the cause. Take a look at the pictures. The crack runs between the sill and the bead. I suspect that the weld puddle was angled insufficiently into the sill, and the crack emerged due to internal pressure on the weld. What caused the crack on this new tub? The cracked area is in the passenger side. At the rear of the sill there is a hole that is replicated on the drivers side. I think this was part of Aqualu design. However, I do not see any drain holes in the bottom of the sill. I think that water may have pooled in this sill, froze, expanded and cracked the sill. This is my best theory so far. I am tempted to just drill out the crack at the ends (stress relief) and lay in a bead of JB weld. Tooling up my mig to weld aluminum is costly, and I am just not that good.
Thoughts on the cause of this crack and possible repairs?
***UPDATE--Hey folks...though this was not installed on a rig before mine, for all intensive purposes it is used. Unless Aqualu has some sort of lifetime warranty that travels with their parts (which I doubt) I don't see how this is a vendor issue. I am seeking your thoughts on what may have caused it and suggestions for repair. *****
it's cracked. get it fixed.
