Builds my 1970 build thread (1 Viewer)
in my little world
my 1970 build thread bad ass
here are some pictures hope you enjoy. this is what it looked liked when i brought it.
frame pictures
this is what the frame looked liked after the powderkoting was done. i also receased the rear and front lights in the bumpers and powderkoted them also.
mow the drive train
here are some pictures of the drivetrain. motor 350 chevy:doh: th350 built trans. stock transfer case. will change to orion after i tear it in two. yes that is carburated. i had it lying around so i had to use it. oh well kept it simple i always say:cheers:
now axles
front axle 4:11 gears new ring&pinion, disc brakes, arb locker, black powderkote. new bearings. rear axle 4:11 gears new ring&pinion, disc brakes, arb locker, poly performance axles, new bearings, black powderkote. extended breathers, yes i know the calipers are on upside down i have turn then upright.
more drivetrain
here are some more pictures of the drivetrain. i put an aa twin stick shifter in. also transfer case saver. everything is steel braided lines. russell fittings, alumiun rad. trans cooler.
body and paint
here are some pictures of the body and paint after i shoot it blue. the paint is from a toyota tacome blue. its speedway blue met. i lined the inside and the underneath. also i welded up the dash and put my own holes in for switches. auto meter guages. this body is not the black one it is another one i had
If that pivot stud is still on the front drive actuator located on the nose cone of the transfer case, I would like to purchase that from you.
attachment.php
cool blue
now after paint. i painted it speedway blue met from toyota. also lined inside and underneath.
a few more pictures. i thought i would take it out for a drive. it needed some air
here are some of the rear with plate. yes it does look like too much but i wanted the tailgate with storage. i will fix it by putting a swing gate on it with the spare tire and gas cans that should hide some so it wont like like alot
roll cage
well i heard you guys talk about full cages. but if it does not go front to rear its not full. i built this one using the black body. i did change the tire so i cut it out. like i said i am going to put it on the back. this goes from the front bumper to the rear. here are pictures of the seats and cage.
roll cage
here are some from the firewall forward. plus i am going to cut the top bar out and put two in and add an overhead console in
Really nice work. The attention to detail is fantastic. Love the engine work.
