After talking to a few guys about tire pressure, I was worried. Everyone seems to have a different opinion on tire pressures when converting from a p-metric tire to an LT tire. Many say you are fine to go by what is written on the door, which is not always correct.
Here is how I personally calculate tire pressure. You need to get the specs from YOUR tire on the sidewall.
The LC200 (5.7L) has a curb weight of 5,690lbs. We need to add some weight because we have 1-2 people, bumper(s), winch, sliders, heavier tires, wheels, skid plates, lights, roof rack, etc.
I don't want to have to calculate all of that, so lets just round up to 6,000 lbs.
6000/4 = 1500 lbs per tire.
The Nitto TG's in 275/70R18 are rated at 3640 lbs @ 80 psi.
If you take 1500/3640 = .412
That means that I am loading up 42% of what the tire can handle (these are load range E tires -- some of you only have D tires).
Now, if you take 42% of 80 PSI you get 33.6.
That means that I should be running NO LESS than ~34 PSI in each tire.
To play it safe, I will run 35PSI and give me some leeway.
I hope this is a "safe" way to perform these calculations, and be sure to let me know if I am wrong on anything.
I just don't want to see you guys running some 28 PSI on the highway like a few have mentioned (not on this forum).
Stay safe!
Stay safe!
