I like BlueWater 7mm accessory cord tensile strength 2600 lbs
or NRS 1" wide polypropylene webbing tensile strength 1500 lbs
I drove a furniture delivery truck, worked on the woods, and did a ton of construction jobs. I have no issue with tying knots in rope, straps are faster, just my opinion.I understand for most people knots can be elusive. I spent 10 years as a kayak Instructor and every day we would have to secure 2-20 boats. It’s a lot quicker then nylon straps when you understand it, plus cheaper.
I was also a yakima rack pro installer at that time so I definitely see the point for the nylon straps.
We load flatbed trucks were I work with Heavy Equipment, of about every shape and size.
Drivers use 10K ratchet straps and check straps (and tires with same bar) religiously.
They told me you would not believe how often straps come loose as freight shifts.
^^X2 I use rope for a lot of functions, but never for securing a load anymore. Ratchet Straps are much quicker.
Roller Cam straps are all I use and need these days; 5+ years and 100% pleased with them on all fronts.
Ratchet straps for my interior & exterior strapping needs are a PITA.
Not your Daddy's cam strap: Home
Thanks for recommending RollerCams!! I had never heard of them... After ordering and using a couple in two lengths (4' and 12'), I can honestly say they are much easier to use than ratchet straps and not nearly as much of a pain in the ass to use and manage.
They hold extremely well and are replacing all my ratchet straps.
Welcome! The Rollercam 1" can be tightened as tight as any 1" ratchet strap I've used. ...
Please explain... seems the leverage one can get with the ratchet strap would allow greater tension to be put on the strap.... no?
The wally world/el crappo/cheap parts store variants IMHO are junk
