Did you do the clear lens swap as part of your retro fit? Also your cutoff is a little fuzzy so you might want to add or remove lens shims to sharpen up the cut off that is if you haven't closed up your headlights already ...neither one of these would change the light intensity so you might just want to bump up to a 5500k bulb and I would definitely check with the vendor regarding the flickering
I used the lens that came with the TSX projectors. Everybody thought the tsx lens was better then the clear lens.
The headlights are sealed already. I sent a email to TRS and waiting to hear back.
Was hoping that you would have the 3D printed projector lens mounting plates available. That would've saved many hours off the retrofit.
Will these "brackets" be lx only? I'm a bit new to hid retro details so if the LC's don't require a bracket just tell and I'll delve deeper. Will the printer plastic handle the heat?They should be done soon...I want to make sure they are perfect. The plan is to offer two brackets... one for the Mini D2S 4.0 ... haven't decided the other projector yet but will soon. We have made 8 prototypes so we are close to a final product
Make one for the tsx since they are widely availableThey should be done soon...I want to make sure they are perfect. The plan is to offer two brackets... one for the Mini D2S 4.0 ... haven't decided the other projector yet but will soon. We have made 8 prototypes so we are close to a final product
Those will workDo the 04-08 tsx projectors work for this retrofit?
Found a guy selling the 04-08 tsx headlights for only $60 for the pair.
Just want to make sure those will work.
Or do I need newer year tsx projectors ?
Thanks
Someone needs to jump on this deal!I have a set of tsx projectors inspected and sold by TRS, TSX clear lenses with spacers, Phillips D2S 4500k bulbs and AMP to D2S ballast adapters. I changed plans and only opened to inspect. $190 shipped to mud member for all.
Interested.
Does this include all the parts needed for the tsx retrofit?
Does anyone have a retards guide to HID projectors for our vehicles? Are you guys replacing only the low beans? Dual demons replace both and one is non functional in the housing? I have black one piece depos coming I want to cool guy up.
Interested.
He sold the parts already
Very Nice Dean! My TSX retrofit is still performing just as well as the day I posted in 2007. I haven't had to service/replace a thing. Thanks for the reference.
Ed
