hi I bought some projectors. From what I can see it’s two pieces. Nothing appears to move inside. Is that right?
also what type of hid/led kit is needed?
What kind of projectors did you buy?
Tsx projectorsWhat kind of projectors did you buy?
Had you purchased Morimoto 8.0 they bolt right on the bracket I designed making the retrofit simple...Tsx projectors
Are you using my bracket with a TSX projector? OEM bracket unfortunately... Pita
I was thinking of trying something like this. I guess this is better than tearing into it again.Look at the 4 tabs on the back of the chrome shroud. I’ve used a heat gun on the two at the bottom and trimmed a bit off the sides of all four which will allow approx 1/8 of movement.
Bend the two at the bottom to lower or raise the height and trim as necessary. If you’re successful you should use a little JB Weld in the slots where the tabs rest and hold in place until it sets. Try this before taking everything apart. They don’t have to be perfect and I think you’ll open up a whole new can of worms starting over,
Thanks for the suggestion. I ended up tearing into it again. Only took about 45 min per side to "adjust" up and down is near perfect, side to side is just a touch off but not enough that anyone including myself would notice from less than 18 inches away staring straight at it so I'd say that is a win. I see that you are in Virginia, wondering if you have ever had issues come state inspection time? Headlight retrofit should fail on inspection. I'm guessing as long as the setup looks clean they are not going not know the difference? Also what about aiming the lights? Am I likely to get away with aimed well enough on a wall 25 feet away? I remember 10 years ago getting dinged on an inspection because my headlights here not aimed "correctly". I think the shop was just taking advantage of me??? anyway have you run into issues with either of these two things? Thanks!Look at the 4 tabs on the back of the chrome shroud. I’ve used a heat gun on the two at the bottom and trimmed a bit off the sides of all four which will allow approx 1/8 of movement.
