slightly more fuel?
Yeah it's a head scratcher for sure. Yes everything with my setup should be ideal. I have not really read any reports stating that they had this turbo running or working where it should yet. I may have missed them though.Damn...
I'm also all out of ideas as well. Everything about your setup is perfect, and there are apparently some aussies running that turbo combo on 4bd1ts without any issues. It should be a tested combo from what is being reported on the net...
How does it run otherwise? Could it be that your pyro is out of whack and reading high?
Would it help to check the timing with a pulse adapter? I can send you mine by mail...
Well yeah everything I read and saw said this we going to be a great turbo. Maybe it is maybe it's just my engine or something? I get 8psi at 1700rpm locked converter and EGT's in the 950-1000+ range. I only get 15psi at the very top of my Rev range and at that point it's useless.I don't know much about this turbo sizing business and I'll admit I bought a 19T compressor housing and picked up some volvo TD04HL turbos based on the internet recommendations. What's weird is I am getting similar/better boost performance to you guys with essentially stock fueling levels. I believe the turbo is a TD05 with a very small compressor housing and fairly large turbine. I am seeing 5-6 PSI at cruise, about 14-15 PSI max in OD (floored at 1800 rpms) and 25+ in 3rd at higher RPMs (2600-2700). I'd say it is faster than a 1FZ except in OD, but then again, I run a higher OD gear so it's not a fair comparison. I guess the sure fire way to find out would be to swap the stock turbo out for the TD04HL 19T, but I've been putting it off since it's a big job and the engine already performs well.
Yeah it sucks.Sorry man. What a bummer on the housing.
FWIW, I have mine back on the road and have essentially the same results as you with the td04hl-18t. The wheel is trashed...but I cleaned it up as best I could and put it back together. I get similar boost numbers to you. And top out at 14psi around 2400ish rpm. I think I have a bit more fuel than you as my EGT's climb pretty quick, but rarely can I get it to top 1200. I don't have black smoke either and would turn up the fuel, but don't want it to melt. I had to back my aneroid off to get it to deliver the extra turns on the max fuel screw.
While I'd love more power, I feel like my current performance is on par with the 1fz I had...what do you think?
I mentioned a compressor leak 10 posts ago. Lol. some turbo's have a deal where the compressor housing meets the turbo. Not familiar with this turbo but it sounds like air is leaking out on the compressor side.
ThanksA professional tuner has vast diagnostic knowledge tools and tricks. Tricks that u ssually dont come out unless its seen in person if you get my drift . Taught me alot of respect from an old drifter. Just trying to save you time and money and ? good luck either way.
