- Thread starter
- #1,081
Awesome build. I am thinking of starting to stockpile parts for a swap of my own. I hope you don't mind a few questions.
I found a 1996 NPR that is running, the owner says it has a blown head gasket though and the engine has over 200k miles. So I am thinking a rebuild from the get go if I buy it. I may go look it over tomorrow morning as the guy says he will be parting it out soon. If I go for the Isuzu to FZJ80 adapter kit, what else should I pull off the NPR?
Maybe most importantly what should I look for and listen for when I take a look at the engine? I have zero experience with diesels but am a pretty good wrencher in general. Sorry for the bit of a hijack.
Thanks! Definitely start early and it's far easier to start with all the mechanical parts off the NPR it will save you time and money later.
A HG is unlikely it's more likely on a 4bd2t that the head is cracked causing the HG symptoms.
Depending on the adapter setup you get/build will dictate the parts you need. I would get the auto bell housing and flywheel/flexplate/converter combo.
Good luck with you swap!
