DanS HJ-45
- Thread starter
- #21
So, with the motor mounts settled, and a little wait for parts (and a flywheel), I figured I'd best get busy swapping all of the stuff from the body of the half cut to the FJ-60.
First up was the PS reservoir. If you aren't familiar with how to do this, a diesel swap probably isn't in your future, but if you want to swap engines from half cuts and things, this is a good skill to have.
So, I'll walk you through the process (most of you should know it already).
Here's about what that list looks like, but with pictures!
- Drill out spot welds that hold bracket to the body
- Clean up the bracket (wire wheel or blast cabinet)
- Place bracket into position on new vehicle, to make sure you've got the position correct. (Toyota generally has only one body, it just gets different brackets welded to it depending on the specific model of truck)
- Weld the bracket onto the new body.
- Prime and paint it to look like it was always there!
