Spudman
Addicted to 60's
Thanks Dan
That's makes sense, I've given it a bit of stick, but haven't seen the red light come on
DanS HJ-45 said:Green light comes on at 2.0 psi of boost. Basically tells you that you are making some boost.
Red light comes on at 15.5 psi of boost. If you get that light, you should back off with the throttle.
At least, the FSM quoted above says those are the numbers where those lights come on.
Dan
And that, for those not fortunate enough to know Dan personally, is why he simply cannot leave the red and green lights unhooked.
Nice work amigo. Hope to get down to lend a hand this weekend.
DanS HJ-45 said:Very true.
Not this weekend, I will be back on the 15th I believe.
Dan
DanS HJ-45 said:I'm back at it.
Dad has been busy cleaning up the 12HT! It looks great!
I did a bit of cleanup of the engine bay. You'll notice that I powder coated the left and right side mud shields. We used Pewter from Shane (that's really more for the 40s) but it looks good in there we think.
I had to modify the FJ-60 left side mud shield a bit to allow it to clear the motor mount and the diff breather. Five minutes setting up the plasma cutter, and 30 seconds to trim it and it. Then, naturally, I powder coated it.
Last of this post is the 12HT flywheel from Georg.
Getting ready to buy a set of isspro gauges for my new to me 61. Mind if I ask where you got them from and which model you went with?
.......that's the pictures for today. More tomorrow, likely of a mess of a wiring harness--because I know you are dying to know what that looks like.
Dan
I couldnt help but notice, the 12ht is going to be 12v? :O
