- Joined
- Feb 10, 2002
- Threads
- 550
- Messages
- 44,831
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
When installing the Dobinsons springs, is it pretty standard practice to install shims of around 4* to correct caster, extended sway bar links (and possibly sway bar bushings), new center pins that accommodate the shims, and new center pin spacers/bushings to hold the axle in place (assuming that the tie rod ends and the steering stabilizer are in good working order)? Are there any other parts that should be installed at the same time? I notice some of the installs in the above photos show a near-perpendicular orientation to the ground for the rear shackles. Can this shackle orientation be made to lay more at an angle by removing a spring from the spring pack? Thanks for any guidance from those who have gone before.
I add 4* shims and new pins to all of my 40/55/60/62 lifts. The Dobinsons shackles are close to stock size but in the best of worlds you are still at plus 1 but closer to zero caster. I like more. Chevys at this vintage have 5* from the factory. More is better.
I use a swaybar kit from Autozone that is about 1” longer than stock. They keep them on the shelf here. Don’t know part number
As for the shackles. Dobinsons designs their leaf springs to have perpendicular shackles. I too had to get it out of my mind that a 45 degree shackle makes the ride better.
Sure it does if your springs don’t flex. Dobinsons uses multiple small highly arched leafs that actually move as you drive over obstacles versus the others that usually have thick springs and lots of them.
