- Joined
- Feb 10, 2002
- Threads
- 550
- Messages
- 44,831
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
With the 4Plus and 60 Dobinsons shock i leave the inner flat washer off
I'll check it out and see.... works on the front...thanksWith the 4Plus and 60 Dobinsons shock i leave the inner flat washer off
Do you do that on the rear too, I took the rear off (I had them on loose, but took them off when I was screwing the the u bolts and leaf spring bushing) ?With the 4Plus and 60 Dobinsons shock i leave the inner flat washer off
@Elbert I’ll add that on the regular shock eyes and the 4Plus flip kit I put on the rear (haven’t gotten to installing my front flip kit yet), I use a really larger fender washer under the nut. The IMS shock eyes seem larger in diameter than the other shocks out there and I don’t want the dang thing slipping right off. Theoretically the bushing should hold it but ya never know. I had no problems getting IMS shocks to work with the flip kit in the rear FYI. Imll be able arching here to see how it goes for you on the front since Imll be doing the same thing soon.
Get the top of the shock mounted and use a bottle jack to push the bottom eye up to the post.yea I think I need to round up a couple of stronger "fender washers" to use....whatever I have from old shock is not that strong...I noticed its bent to some degree. On the rear. (noteablly on the top).... not sure on the bottom. I have to re-do the rear shocks because I had them loose and got side-tracked with outher things and late the evening I noticed I had to re-vist the rear shocks, but ran out of those large tie straps.
its a battle to compress those shocks and then its a battle to rig up a way to keep them compressed. Some shocks come with some large plastic tie strap type of things...adn they don't interfer with the install and you simply cut them when you get the shock mounted on one end and then guide the top or whatever to the mounting point.... depends on design of shock. Always a little tricky and aggravating dealing with the front shocks in my view and I think the dobinson eye is larger which normally would not be a problem but is aggravating in my view. I'm doing the work with the truck up on jack stands so that makes it a little more fun, than having a lift.
I tracked down the OEM lower shock bolts on the Bay. My originals were rusty and not worth saving. The threaded section was plenty long enough to torque down properly, and the built in concave "washer" made the fit just right. My IMS shocks came with upper pieces for fitment.yea I think I need to round up a couple of stronger "fender washers" to use....whatever I have from old shock is not that strong...I noticed its bent to some degree. On the rear. (noteablly on the top).... not sure on the bottom. I have to re-do the rear shocks because I had them loose and got side-tracked with outher things and late the evening I noticed I had to re-vist the rear shocks, but ran out of those large tie straps.
yeah....are you talking about the rear shocks? I thought about that...but not yet tired it.Get the top of the shock mounted and use a bottle jack to push the bottom eye up to the post.
Tried it both ways. Hanging the lower and the upper first. As I recall, I found it easier to hang the upper and lift the lower in to place. Used a bottle jack for one. That got frustrating. The last three, just muscled them in to place. Once you get the shock to start compressing, the process moves along smoothly. It's the initial compression that requires the muscle.
Sweet rigs! Where did you purchase those grey steel rims?I have the MRR on my 60. I’ve installed 3 on 60s. 2 on 200s.
I have IMS on 3 40s and my 80.
The IMS and MRR share the same body.
Personally I prefer the IMS for most applications because Dobinsons has that shock super dialed in.
The only complaint about the MRR is that it
Is so adjustable I find myself always messing with them.
My 60 rides great.
Here are two of them.
This is much smarter than what I do. I attach the upper eyelet and loosley bolt it in. Then i position myself to get leverage from the ground and whatever i can and push off of with my legs using the motion from the second part of doing a squat at the gym. Then just push the shock in manually. It always works. The key is to use zero arms whatsoever and keep them locked and use your legs to push your entire body, which will in turn push the shock. Cant guarantee you wont get a hernia though.this might help someone in the future. I'm sure there is more than one way to "peel the orange".
in my shop area I don' t have a good place to immobilize the the shock and get it tied down as I would like (compressed for install). Where I could use mechanics wire or some other approach. I also am working on jack stands.
so what I did was use large zip ties. ON the rear I measured the distance between the two points (shock mounting points) I then made a crude template by chopping the end of one of the long tie straps to something close to 21.5 inches. So I then compress the shock (manually) and I have the zip ties on there loose, and when I get to the approx distance I tighten up the zip ties to hold the shock> (i'm doing this manually) so the abity to hold the shock compressed and tighten the zip ties is fun to do. Outside of the vehicle...
Then I mount the shock at the rear top mount loose, and see if I can get the bottom mount to line up, where it if does not then use a small bottle jack to compress the shock further and retain the setting by further tightening the zip ties. then move the bottom of the shock to get it mounted to the bottom mount, this might take one take or a couple. The driver side is eaiser to deal with as you are not so close to the rear diff. I'm basically laying on the cement slab to the rear of the rear axle and doing "it".
I scratched the hell out of the shocks but whatever....(before . screwing around with different attempts). This is one way to do it, if you are on jack stands and have lmited ability to otherwise tie the shock down in some manner thats easy.
You can get the long 24 inch or so HD zip ties from Lowes or other places, in my area its Lowes.
Anyway thought it might help someone in the future., notably if you are doing this by yourself.
Hope this made sense , if you need to pm me or something I'll tell you what I know etc or my experience...
If I had a welding table or large shop table I probally could have come up with a clean way to hold the shock and compress it and then secure it.....
When I switched to the Dobinsons IFS, I replaced the nasty old oem bolt/washer combo with new oem. They've held great. No worries about the old stuff failing.
Do I just need to replace my cupped washers with new OEM? Or do I need larger ones to run with these IMS shocks? I wasn't having this problem with the Bilsteins I removed.
