Dazed
Blue's Driver
- Thread starter
- #21
Based on the "best" place we had it, that picture is a couple inches too close the to drivers side.
I thought that I had read Doug's and Don's threads enough times...apparently not!
From the sounds of things and rereading Doug's thread, where it goes in the engine compartment doesnt matter and doesnt affect too much of anything other than fit. All of that being said, I think that I prefer to the keep the driveline in the stock location, it is far less hassle for me; I dont think that the Alternator is an issue with the engine moved over slightly; I dont have firewall issues with the engine at 1.5deg; the only issue is then the turbo, which sounds like it can get sorted with a hydroboost unit that is basically bolt on (I do still need to look into it more), or I can fab a slightly different turbo mount.
I will be going and getting two pieces of 6" length of 6"x3" box cut at 40deg later this week for engine mounts.
Bluehawk, I am using an H55F, it is the same as a stock trans from 85+ (check the month though!) I did an OME heavy+ lift (expedition rig). The starter doesnt work at all with the oil filter block off plate. The space is 0.8" IIRC and the blocking plate is 1.0". Dustin is already aware of this and is working on it. I am putting on a different turbo and the plan is for an intercooler. My inlet piping will go over the top too to a cyclone (I dont remember the LC model, but the mounts need changing) type filter. The hardest part has been all of the small stuff that keeps going wrong or needs replacing when I rebuilt the engine. I have a ton of pictures and I plan on writing a post build/rebuild thread/book on it, along with lessons learned....or that is my hope.
Mitch
Mitch
