Dazed
Blue's Driver
So I managed to get my 4BD1T into the FJ60....well sort of. The transmission is mounted in its stock location and the 4BD1T is attached to it. There are a few fitting issues that I am having that I hope people have already solved.
On the passenger side rear of the engine, the mount/bracket is contacting the firewall, how was this worked around?
The heater pipes are near the same location as the mount above and I am not sure how to access them or get hoses to them later. How was this solved?
What was the level of people's motor mounts? Can you supply pictures. I think that at best, the motor mounts will be even with the frame; aka the bolts will be at frame level (the 2F's were slightly above frame level).
How much clearance did you guys have beteween the Alternator (or AC, depending on your set up) and the steering box? I have very little.
Also, did you really put the engine in, fit it, and then pull it out again and weld up the engine mounts? It was a real PITA to get that sucker in there and get the tranny aligned properly!
One last picture in the next post....I have no idea how to paste pictures in-line.
thanks in advance.
Dazed
thanks in advance.
Dazed
