Ok cool. I think mine will take a bit more fab and work. I need to look into the radiator drain plug and the coolant outlet...forgot about those.
I know I can make it but it's more a point that I already paid for it and the part he supplied didn't work....principle of the matter.
I am sure I am missing some more stuff, but that is plenty to do! Still hoping to have it ready for Cruise Moab but that is looking less likely sadly. I would like to have driven it for a bit before going on such a long trip.
If anyone is in or going to be in Santa Barbara this weekend and wants to help out, hit me up.
Mitch/Dazed
Thanks. I finally have an extensive list...it's long.
One thing I'm struggling with is the electrical (I don't remember where it is in your threads). How did you guys modify your wiring harnesses? I didn't label all (any) of the connectors...oops. I know where the alternator connector is. I am not sure where the temp sensor connector is, the oil pressure sensor connector, nor the Air conditioning compressor connector. All the others are obsolete now.
I also need to figure out where I can get 12v only when the ignition is on...where is that wire?
Where on the harness did you modify your harnesses? Did you leave them in the vehicle to modify them?
Luckily I don't need glow plugs to work for the engine to run.
Another question. Could I remove the fan shroud all together and mount some fans on the radiator instead? Might be much easier if I can get the cooling I need.
A/C wire is green single and its on the passenger side
Alt wire is a 3 wire jobby with a round receptacle
Temp sender is single wire with spade terminal centrally located. Sorry don't remember color
12V ignition on is your hot wire to the distributor
Oil pressure is also single wire, don't remember color, has spade end on passenger side as well. Get an oil pressure unit from mid 90s V6 Toyota truck. It fits in one of the oil ports without issue on the drivers side of block by oil pump housing. Also has correct ohm rating for proper gauge read.
Wire harness can be modded in the vehicle. If you can even call it that. I built my fuel cut system outside the vehicle then ran it from a separate fuse block.
Everything else I pulled, re-routed through the fenders, and just spliced as needed. Everything got tested multiple times before the solder and heat shrink came out.
Dual elec fans are your friend. You need the Ford Contour set up for V6 model. Any decent auto supply will have it for around $120. I ponied up and bought the painless fan controller.
That's all I can remember for now. Look through my thread for any specifics. PM me and I will give you my number. Feel free to call and pick my brain on anything you need. I can hang out with my hood open and walk you through some of the wiring, plumbing, etc.
I will be at Cruise Moab barring traveling issues. Hope to see you there.
Clint
