Factory on mine uses two per side fwiw.Clean install. How many bolts did you use to mount the plate to the frame? Some have used the two per side from the hooks, and some have drilled a 3rd hole to line up with the one further back on the frame
How easy is to get to the winch clutch? I coudlnt tell from the pictures. Can you see how the drum winds up too so you dont end up with a bird's nest? Looks pretty neat, bring it to the Meat and Grits next month.
I just need to say - "Stan said we needed this if we wanted to do stuff with the club." That may work.
OK - it is 23" wide by 7" tall not counting the control box, which does have bolts holding it down.
Pics:
