Which looks better
Folsom, CA
Bad thing about this guage setup is cutting the old screw tabs out of the LC dash. Pains me to cut on that dash. But. heck, I have cut other parts of my cruiser.
Depends on the kind of setup you have. Are you going with a strict wheeler where body damage and fenders dont matter, or are you going with a DD that looks good.
Personaly I like the new guage set up. over the old.
Pics of your rig would help greatly.
In my opinion it's up to you what you think looks better not us. I like the old look. If I were going to do the new guage setup I would mount the guages so when everything is normal all the needles would be pointing in the up position. (except tach and speedo) Makes it easier to just glance at guages to make sure all is good. But it doesn't look as good this way. It's up to you though.
By the looks of the photo your Idling a little low. :D
sharp lookin new cluster, I know I sure like the new gauges in mine much more than the old stuff....
shoulda put an hour-meter in there tho, odometers are overrated!
nicely done! :D
Thanks
I really just wanted to show off the gauges, but I really do appreciate others opinions.
The only real hassel with these new gauges is getting a new speedometer and getting the fuel gauge to work.
yeah, the ohm's for the sending unit signal can make a mess....still got the stock tank or ??
I opted for no speedo on mine, figgered it was worthless on the trail and near-worthless on the street....tho, with the D300 case, it would at least be an "easy" hookup now...
(BTW: just took off a pair of your brake brackets.... ;) )
very nice
I can read the speedo, tach, volt, gas,temp....but what is
the other one? Anywho...nice set up.
I'd like the new one better if it was o.e.m. color. Just my take.
That's why they make chocolate and vanilla. I say go with
what floats the pontiff's boat.
What it shows
The guages are autometer Arctic White
Speadometer, mechanical
Tach, 7rpm
Water Temp
Oil Pressure
Fuel level
Volts
The color scheme on our truck is Viper Red/Black. So the guage plate is Black along with the Glove box door.
I still have the stock tank. But, the new gauge came with a sending unit that will not be to hard to adapt, so others have said?
I don't make the disc brackets anymore. JT outfitters sells them cheaper than I can have them made.
BTW Woody, I getting my webpage pack up with all my tech stuff active.
i like the new, and if your not trying to keep the truck stock i say do it.
Drilling the tank
I've needed to drill new holes in my tank to properly mount my aftermarket sending unit. It uses a 5 bolt flang instead of the 6, or other way around. I am scared of just drilling the new holes in the tank for fear of explosion. Did you purge the tank with argon while drilling, or did you drill it without. If you did it without argon, would it be safer with a full tank or empty tank. The full one would have less fumes to ignite.
I have the same set of gages you do Cardnal. I used the oem fuel plate and just modified the new sending unit to fit on it. By doing this, I didn't have to drill into a bomb, and I was sure that the fuel plate would fit perfectly. I just cut off the old sending unit and bolted the new one on. I like the new gages too.
zglad-
Didn't you post this up some time back?
I was searching for it, I know someone had posted up something about modding the sending unit and not the tank....
Thanks!
:beer:
-Steve
zglad. That sounds like the route to go. I will look into that tomorrow. Thanks all for the good input!
